hawk89
This is super simple! Just point the phantom in the direction of your choice and take a picture then rotate the phantom to the left or right depending on which direction you want to capture and take another picture. I would recommend between 2 an 4 images. It is smart rotate so the images you take overlap quite a bit (about 1/3 of the first image should still be in the frame when you take a second image), this makes a better panoramic image. I used Lightroom CC to merge the two images but there are many free apps that can merge panos. I shot the image in the DNG raw format and did quite of bit editing really bring the color out using lightroom CC.
Had to re-size so it would be less than 1000KB for this forum which is lame. The original image is much higher resolution.
Let me know if you guys have anymore questions!! |
