dramsey
Flight distance : 2894 ft
I just received a new P4P+ V2.0. Out of the box I charged the battery and RC, updated the firmware using DJI Go 4. These updates included battery firmware updates that DJI GO4 said were required. I was then able to successfully test fly the P4P and everything seemed good. The next day (after charging the batteries), I attempted another flight. However, this time, the RC controller screen could link to the P4P, and I could see the camera view, but I could not control anything else. DJI GO4 does not recognize that there is a SD card installed (it is), It cannot provide any battery info, nor any other information relative to the P4P. The gimbal control does not work, and, most importantly, it will not turn on the rotors. On the P4P side, the rear LED's under the rotors are not on (as they typically are), neither are the front LEDs. The small LED on the connection button between the USB port and SD slot flashes to a solid green at first, but then flashes Green-Orange-Red in a continuous cycle. I've tried everything I can think of from trying to re-link the RC (no good), to attempting to upgrade the firmware on the P4P with DJI Assistant 2 for Phantom. When I use the DJI Assistant 2 app. I get an error mid-way through the update that identifies a battery update error. Following the instructions of extracting the battery and reinserting does not work. I am at a loss. Here is the screen shot of the Assistant 2 error (BTW, I have three batteries and they all behave the same way):
Battery update error
