Fan issues
1088 10 2018-7-17
fans6690a80a
Hi, Hi keep getting error message aircraft core board overheated, fan was working fine then seem to stop after an upgrade was done and have only had drone 3 days! Has anyone one else had same issue?
2018-7-17
Bill B
Flight distance : 319245 ft
I have read other posts to the same problem. I would start a ticket with DJI and return it for another.
2018-7-17
DJI Paladin
Flight distance : 318 ft
Sorry to hear about that. May I know if you always have the warning message on the APP screen after turning it on for a while? If it appears frequently, please post a screenshot here. For the fan issue, would you please record a short video for evaluation?
2018-7-17
fans6690a80a
Bottom side of drone heats up to point you can’t touch then message comes up.
2018-7-17
fans6690a80a
Screen shot of message
2018-7-17
MrArcher
Flight distance : 401706 ft
Return it to the store if you can. If not, make a ticket and send it to DJI. Something is definitely not right.
2018-7-17
DJI Tony
Hi, I would suggest contacting our support or you can reach the re-seller and process a replacement. Kindly see the link below for you to contact our support.
www.dji.com/support
2018-7-17
fans6690a80a
I read another post that said check fan is not getting stuck and on inspection found the front steel mesh was up against the fan I moved it back with a tooth pick and fan now running ok and temp ok I’ll see how it goes.
2018-7-17
HedgeTrimmer
Missed screen and toothpick.
Any idea how screen got pressed into fan?
2018-7-17
HedgeTrimmer
MrArcher Posted at 2018-7-17 06:01
Never mind.
2018-7-17
MrArcher
Imho, I'd still return it. You have no idea what in the manufacturing process caused this OR more importantly, does this suggests something else might be compromised as well? This could be an indicator of other issues, so just take it back while you can. If an expensive electronic device doesn't work correctly right out of the box, return it.
2018-7-18
