DJI Tony
Hi, no need for clarification, the case that you received is for the Osmo Pro combo kit with extra accessories so that you could be stored all of the items that you need in case that you're using Osmo Pro combo with additional accessories, however, since you're using the Osmo+ and this case is large for your unit including your accessories, meaning it's not necessary for you to use this case unless you're planning to upgrade. Kindly check the image below for reference.
