Nexus 7 - Tablet Interference
2018 8 2014-11-3
jasonmsprague
Flight distance : 233953 ft
I recently purchased my P2V+ a few weeks back and love it.  I recently tried using my Nexus 7 as a monitor for a bigger screen but am running into interference issues.  When using the Nexus 7, at about 500 - 600', I loose control signal, sometimes much closer.  If I take the Nexus off the mount and hold away at arms length, I can regain control and travel further.  When bringing it back towards the controller, the connection is one again lost.
The Nexus does not have cell support and other than android system apps, nothing else is running.
Any ideas why the Nexus would cause interference?
2014-11-3
DJI-Blair
China
Let me confirm:
When you use Nexus 7,the drone can fly about 500-600 meters and the controller will lose signal and the drone enters failsafe.But if you do not use the Nexus 7, the drone can go much further .Am i right?
Do you try it on different mobile devices&locations?
2014-11-4
jasonmsprague
I was referring to feet not meters, so only about 150 - 200 meters using the Nexus 7.  When I use my Galaxy 5s phone, I get about 400 meters.
2014-11-11
DJI-JS
Flight distance : 48940 ft
When you mount the Nexus 7, do you have to change the RF antenna and WiFi extender orientation? Say when mounting the Nexus 7, do you have to make the RF antenna tip pointing the craft instead of the body of the antenna? the tip of RF antenna is actually a weak point of RF signals for reviving and emotion.
2014-11-11
jasonmsprague
No, the mount for the nexus fits more in the middle of the controller than the top like the phone does.  This way I can continue to tilt towards the phantom.
2014-11-15
jasonmsprague
Like before, if I hold the Nexus away from the controller, than it reconnects quickly.  It would appear like the Nexus was causing interference of some sort.  If it is due to proximity to the antennae, where can find information on an antennae upgrade or something to increase the control range?
I appreciate your help!
2014-11-15
jmtw000
To be clear, are you losing control (the Phantom starts to return home) or are you just losing connection in the app? Either way, maybe you can shield the tablet somehow.
2014-11-15
Gerry1124
I have an Apple ipad.  I have it centered on the transmitter with 2 clamps and have no problem at all having a solid connection.  I did move the range extender velcrowed to the back of one of the clamps at the top of the clamp.  All equipment is stock and so far, the distance I have gone in an open area is 3400 feet from take off point.
Apple iPad 2 32GB, Wi-Fi + 3G (AT&T), 9.7in - White!! (Low FW iOS 6.1)
2014-11-15
jasonmsprague
Yes, the RF connection is lost, not the wifi.  The Phantom starts to return home.  I agree shielding is likely the only fix as the issue does not happen with my phone.
@Gerry1124 - That is amazing distance.  The furthest distance I've achieved is 1200 feet @ 200' altitude and 1500' altitude @ 100' distance.  All equipment is stock Phantom 2V+ using a Samsung S5 Active.
2014-11-19
