Settings won’t stay
1491 21 2018-7-22
Newmant009
Flight distance : 578337 ft
Every time I change the setting and push done it just returns to 0 I have reset the controller reset the bird
I have tried to delete the app and reinstall
I have created a new account
I have tried 5 different phones now including an android and apple phone and nothing will let me change the settings and I’m getting very frustrated
My old man has exactly the same drone and has had none of these problems
Please help!!!!!!
2018-7-22
ALABAMA
Flight distance : 10442687 ft
Make sure your drone is on when changing settings.
2018-7-22
DJI Gamora
Hi, thanks for reaching DJI Forum, we do feel sorry to learn that you are currently having issues with the settings of your device. Just to clarify what is the settings that you are referring to? Is it the camera, gimbal, video ? We're here to help. Thank you.
2018-7-22
Labroides
Flight distance : 9991457 ft
Many settings are stored in the Phantom, not the phone or tablet.
To change those, you must have the Phantom connected.
2018-7-22
Phantom4thebest
Flight distance : 107648 ft
Have you tried hard restarting the drone? by shutting it down from battery then pulling the battery out for 30 mins to an hr then turning it back on? fixed a similar problem with one of my phantom 3 SEs
2018-7-22
Newmant009\
DJI Gamora Posted at 2018-7-22 14:27
These are the basic settings
I’m only trying to add the return to home altitude
I have tried it with the drone powered on and off
It won’t allow me to take off without doing it manually and every time I push return to home it just keeps saying “timeout” I think this might be bacause at the moment I can’t change the settings so it is set at return to home at 0
https://m.youtube.com/watch?v=I1pOUcUqUf4
2018-7-22
DEUCEDOG
Flight distance : 2501575 ft
Try moving the ac to get a good gps signal , see if that helps ? and also are you logged into your account ?
2018-7-22
Newmant009\
DEUCEDOG Posted at 2018-7-22 22:31
Yes logged into my account and also I have tried exactly the same out side with 15 signals at one point
2018-7-22
Newmant009\
Newmant009\@aol. Posted at 2018-7-22 22:55
I have also tried resetting the RC to the drone and still the same problem
2018-7-22
Labroides
Newmant009\@aol. Posted at 2018-7-22 22:15
I think this might be because at the moment I can’t change the settings so it is set at return to home at 0
Your video shows the RTH height at 0 metres.
That's a huge clue.
It's telling me that you do not have the drone connected.
The minimum height for the RTH altitude setting is 20 metres.
Yours is showing zero because the drone is not connected and the app has no way of telling what has been set in the drone or of changing it.
2018-7-23
Newmant009\
Labroides Posted at 2018-7-23 00:12
That's a huge clue.
I can view the camera on my phone is this different
If the bird is not connected to my phone how do I change this
2018-7-23
Newmant009\
That's a huge clue.
2018-7-23
Labroides
Newmant009\@aol. Posted at 2018-7-23 00:54
Something isn't adding up.
Having zero showing indicates that there's no connection to the settings which are in the aircraft.
You say the camera view is working which would indicate the aircraft is connected.
I'm not sure what would explain that.  I've not run into it before.
Until you can see the aircraft settings, you won't be able to change them.
2018-7-23
Newmant009\
Labroides Posted at 2018-7-23 01:02
I have been able to see them once before because I took it out of beginners mode since then it has not worked
2018-7-23
DEUCEDOG
This is a bit odd? .... the only other thing i can think of  is to refresh the FW in the AC and Rc and them relink them , when you do all this ensure batts have a full charge  . Let us know how you get on
2018-7-23
Newmant009\
I’m literally lost, I have tried to reset all and have three batteries which all have full power
I have reset the bird and re linked the controller tried to add a new account to the drone and this all still don’t work
2018-7-23
ALABAMA
If you have tried all the suggestions here and are still having this problem, time to send to repair.
2018-7-23
Newmant009\
ALABAMA Posted at 2018-7-23 03:27
I’ve only had it a month where would you send it to repair
2018-7-23
ALABAMA
PM an admin and they will help you.
2018-7-23
Peterx
Flight distance : 1499708 ft
Do you have a shot of the Go app screen?
2018-7-25
G_Sig
Flight distance : 9109311 ft
Iceland
What  drone and what app?
2018-7-25
Newmant009\
Sent it back the drone was faulty, it was the phantom 2 a friends drone
2019-7-31
