Non-P Mode
1578 3 2018-7-23
charithjcooray
Flight distance : 3251 ft
Sri Lanka
My Spark in take off always says it in Non - P Mode, ill try to cheng the mode in remort but it not works. then i try when it was flying it also not work. in non p mode i cnt cheng the mode in  the dji go app. also i cant do inteligent flight modes. how can i fixed it? it under warrenty piried.
2018-7-23
DJI Paladin
Flight distance : 318 ft
I'm sorry for the inconvenience. May I know what is your mobile device, firmware version and DJI Go 4 app version? What is the current mode of the aircraft? Please click on "Reply" to make sure that I can get a notification from your response. Thank you for your support.
2018-7-24
DMX_MT
Malta
Did you try to fly your Drone outside, to get a Good GPS Signal ? I assume that you are in ATTI Mode right now.
2018-7-24
ssakellaro
Flight distance : 28058 ft
Greece
If you are outside wait for the satelite count to increase (above 10) and then liftoff. If you are inside GPS will not work
2018-7-24
