Changing Props
niktnowy
Hey everyone. At what point would you advise to change props on P3P?  I  run into  furniture during indoor test. Nothing really happend. Props show some very tiny scratches but Drone perfoms well.
What is a best way to change props?
I tried to change prop to new one but cannot hold rotor to uscrew props.
Thanks
2015-5-22
dundee
Flight distance : 33550 ft
Thailand
You could use an oil filter wrench
2015-5-22
mike
Flight distance : 228255 ft
Props should be changed when they are chipped or cracked. Some scratches should be okay.
You can remove the props using the prop wrench from the small silver bag that came with your Phantom.
www.PhantomHelp.com
Find the latest must-haves, fixes, mods, how-tos, guides, and accessories for your Phantom.
Phantoms in stock and ready to ship worldwide! (see availability)
2015-5-22
aburkefl
Flight distance : 78612 ft
Your Phantom should have come with a small silver bag. Inside that bag should be a couple of plastic retaining screws, a replacement set of "shock absorbers" (for your gimbal) and a small wrench.
On my wrench, the slot is just a silly super fraction of an inch too small to fit one of the bars on the side of the motor. It actually fits just a bit better if you gently wedge the wrench onto a top-side bar, then lever the wrench down, so it's out of the way (of course, as you do this, you retain the purchase on the top bar).
With the wrench like that, you can tighten/loosen the props far better than just by hand.
2015-5-23
yvesvn
Flight distance : 840879 ft
Belgium
I am using my PH2 props with Alu ............it seems that the originals(PH3) are not always holding very good ???? Take care not to tighten to hard (not use the wrench)
2015-5-23
MikeAngelo
The wrench has been useless for me.  I hand tighten before each flight, and remove them as soon as my flight is over.   Thus, haven't even taken the wrench out of the bag.
2015-5-23
