djiuser_NofgN916jMP5
Czechia
Hello everyone,
today I had really bad day. I wanted to show my drone to my granparents, but my drone crashed from +- 5 meters when I wanted to land...
It seems everything is okay, but the cover has cracks. Can you tell me what happened? Here's the log.
Did I lose my warranty?
Thank you for answer.
Have a nice day.
-97.702 : 703 [LED] changed: normal led
-97.360 : 720 set_get_real_name_info
-97.360 : 720 get_real_name_info:ad
-97.280 : 724 set_get_real_name_info
-97.280 : 724 set_real_name_info,data: 1534609480, flag: ad, len:27 14
-97.020 : 735 [FDI AHRS[1]]mxyz)compass stuck!!!
-93.162 : 928 48.7911811 14.4563320 594.74 First Home Point
-93.162 : 928 [whitelist]invalid flash key
-93.162 : 928 [whitelist]data len invalid
-93.162 : 928 > whitelist inited [0]
-93.162 : 928 [whitelist]>test data injected
-93.142 : 929 airport limit data need update[1096071196][1610612736]
-93.042 : 934 [LED] changed: set home
-91.542 : 1009 [LED] changed: normal led
-25.322 : 4320 [LED] changed: rc completely lost
-18.722 : 4650 [LED] changed: normal led
-7.580 : 5207 sub_cmd:9,data_len:14
-7.580 : 5207 MONITOR_CHECK_UUID_SET status:1
-7.580 : 5207 sub_cmd:10,data_len:15
-7.580 : 5207 set app type:1
-6.600 : 5256 [BAT][APP->BAT] ACTIVATION_VERSION!
-6.480 : 5262 [BAT][APP->BAT] NEW_ACTIVATION_GET!
-3.060 : 5433 set_get_real_name_info
-3.060 : 5433 get_real_name_info:ad
-2.982 : 5437 set_get_real_name_info
-2.980 : 5437 set_real_name_info,data: 1534609575, flag: ad, len:27 14
-.062 : 5581 [M.Start]REQ_RC_NORMAL
-.062 : 5581 [Ctrl<2>] REQ_RC_COMMAND ENGINE_START ctrl_engine_start
-.042 : 5582 [IOC.CL ] 141.6 Degree
-.042 : 5582 [TO.ALT ] 576.930054
-.042 : 5582 48.7911820 14.4563463 596.93 Home Point
1.338 : 5651 [LED] changed: set home
1.958 : 5682 [Ctrl<2>] REQ_RC_COMMAND ASST_TAKEOFF_HOLD ctrl_asst_takeoff
2.838 : 5726 [LED] changed: normal led
3.978 : 5783 CTRL reset all by assisted takeoff finish
3.998 : 5784 [Ctrl<1>] REQ_RC_NORMAL ATTI_HOLD ctrl_gps_atti
68.238 : 8996 [M. Stop]landing.RC_Thr
68.238 : 8996 Motor Start 1 Total 68.30
68.238 : 8996 CTRL reset all by motor stopped
70.278 : 9098 iwdg_set_max_timeout befor set swdg_timeout(0x00000120)!
70.278 : 9098 iwdg_set_time_out time_out(0x00000ffa)!
70.278 : 9098 iwdg_set_swdg_time_out time_out(4090) set g_swdg_timeout_max(0x000007ab) ||
77.058 : 9389 [M.Start]REQ_RC_NORMAL
77.058 : 9389 [Ctrl<2>] REQ_RC_COMMAND ENGINE_START ctrl_engine_start
77.078 : 9390 [TO.ALT ] 578.669617
77.078 : 9390 48.7912608 14.4563608 598.67 Home Point
77.718 : 9422 [LED] changed: set home
79.078 : 9490 [Ctrl<2>] REQ_RC_COMMAND ASST_TAKEOFF_HOLD ctrl_asst_takeoff
79.218 : 9497 [LED] changed: normal led
111.778 : 11125 CTRL reset all by assisted takeoff finish
111.798 : 11126 [Ctrl<1>] REQ_RC_NORMAL ATTI_HOLD ctrl_gps_atti
204.678 : 15770 [Ctrl<10>] REQ_RC_GO_HOME NAVI_GO_HOME ctrl_navi_go_home
240.918 : 17582 [LED] changed: rc completely lost
241.718 : 17622 [LED] changed: normal led
244.818 : 17777 [Ctrl<10>] REQ_RC_GO_HOME AUTO_LANDING_HOLD ctrl_auto_landing
245.300 : 17801 sub_cmd:10,data_len:15
245.300 : 17801 set app type:1
245.300 : 17801 sub_cmd:9,data_len:14
245.300 : 17801 MONITOR_CHECK_UUID_SET status:1
246.520 : 17862 sub_cmd:9,data_len:14
246.520 : 17862 MONITOR_CHECK_UUID_SET status:1
250.958 : 18084 [LED] changed: rc completely lost
251.358 : 18104 [LED] changed: normal led
253.660 : 18219 sub_cmd:9,data_len:14
253.660 : 18219 MONITOR_CHECK_UUID_SET status:1
253.680 : 18220 set_get_real_name_info
253.680 : 18220 get_real_name_info:ad
257.560 : 18414 set_get_real_name_info
257.560 : 18414 get_real_name_info:ad
263.178 : 18695 CTRL reset all by App Go-Home Exit
263.198 : 18696 [Ctrl<1>] REQ_RC_NORMAL ATTI_HOLD ctrl_gps_atti
318.258 : 21449 [M. Stop]landing.RC_Thr
318.258 : 21449 Motor Start 2 Total 309.50
318.258 : 21449 CTRL reset all by motor stopped
320.298 : 21551 iwdg_set_max_timeout befor set swdg_timeout(0x00000120)!
320.298 : 21551 iwdg_set_time_out time_out(0x00000ffa)!
320.298 : 21551 iwdg_set_swdg_time_out time_out(4090) set g_swdg_timeout_max(0x000007ab) ||
333.958 : 22185 [LED] changed: rc completely lost
336.980 : 22336 Battery power off
