mackjam
Zimbabwe
Had a flip over at 2.5m altitude above the dam, about 3m from the houseboat and it disappeared in 4m of green, but fresh, water. Battery was at 57% so I knew it was something else. Grabbed my fishing rod and put on my biggest tiger hook. Luckily I snagged it first time and after recovering it and quickly removing the battery, I took the top off and discovered one of the wires to one of motors had broken off it's ESC PCB at the solder point. It is a P2V+ (V3) with the 2312 motors and solid wires. From reading some related posts and general experience, I'm guessing it was a stress fracture of the wire from vibration, as there is no stress relief on the wires and they must vibrate quite a bit. (I also have a P-1.1.1 and it has the motors with multi-core wires - much more reliable design I think). I stripped it completely (incl the camera and gimbal) and left the parts on deck for a day in the hot sun and wind. After I'd put it all back together again it appears only one ESC is toast (strangely NOT the one with broken wire - that one's fine), everything else seems to be ok! Can't believe the camera and video transmitter survived. Going to need to do some hot glue mods on all the ESC motor wires to prevent it happening again! Guess I was lucky it hadn't happened at altitude over land and, if it had to be over water, so close to the boat so I could recover it. Now just trying to figure out how to get a new ESC delivered to deepest, darkest Africa . |
