Blériot53
Flight distance : 6260935 ft
When using Litchi, if you programme a waypoints mission and upload it to the drone, assuming you have ensured sufficient GPS satellites locked, once it sets off, it will follow the waypoint track even if the RC loses contact with the drone. That's what it is designed to do. You should ensure that the battery is sufficiently charged to complete the planned flight. But if the intelligent flight batteries detect a critical point of charge, the RTH will initiate and bring the drone back home. This is fine if there are no obstacles higher than RTH altitude between you and the trigger point when this occurs. Planning and re-checking are essential if you're going to attempt to do this. Bearing in mind that you'll be outside the guidelines of the drone code ( ie keeping the drone in VLOS all the time.) |
