Following my post about a problem in the new Mavic pro 2,
Enclosed are videos I took of the problem.
DJI support devision has responded promptly, gave a few suggestions (Which unfortunately did not solve the problem) and asked for these videos.
So far it seams that they take the matter siriously.
I'll keep you updated.
https://youtu.be/BmjlyGWg3OA
https://youtu.be/S3P-vKyqTtI
Encoded is the previous mail I sent DJI
I have purchased the new Mavic 2 directly from DJI and received it yesterday. I have a lot of experience with operating and flying drones, especially Dji drones. I have owned Dji drones since your first product was out. The new drone Mavic pro 2 looks and feels amazing. However, after I studied it thoroughly and saw all the tutorials, I have tried to operate the new drone, but before I could even lift it off the ground I came across a severe problem with the camera gimble that prevents me to use it. It looks like the built in camera gimble is defective. It doesn’t preform as it should be. It is moving quickly, brutally all over up and down very quick, hits the body of the drone non stop and uncontrolled. When I turn the camera off, it stops facing half down. From time to time the shaking to all directions stops and the camera starts to tremble up and down very fast. I can’t control the camera with the tilt gimble button of the controller, neither using the app. As long as the aggressive movement of the camera continues and the app is on, it operates on visual and you can see through the lens the aggressive movement view. Important: I am not referring to the normal set up synchronizing of the camera. I am talking about a defect in the camera gimble. The problem occurs when the drone is synchronized with the controller or when the drone operates without the controller, with or without connecting to the app. I have tried to replace the connector cable between the phone and the controller. I tried to use the micro USB port on the left side of the controller and the USB port at the bottom of the controller. I replaced 3 fully charged butteries. I linked and unlinked the drone from the controller as specifies in the operation instructions I am a professional commercial drone pilot and I need an immediate urgent solution because I have a specific project I purchased this drone for I need it immediately.
I bought the drone during the NYC launch after waiting for the launch a long time, and I’m highly disappointed.
Uri Iram
USA
uriiram@gmail.com
www.besthomephotos.com
