dji go 4 has stopped working
1513 17 2018-9-2
Hakan81
Turkey
hi, my phone can only open dji go v4.4.1.3, all other versions gives same error while opening it, "Unfortunately DJI GO has stopped working". (this version of dji go is very slow, plus crashing often.
i own dji spark, my phone is asus zenfone 6 with this spesification:
https://m.gsmarena.com/asus_zenfone_6_a600cg-5953.php
(2 gb ram, now 4gb free space on sd card)
please help.thank you.
2018-9-2
Alex Batalov
Flight distance : 21105262 ft
First uninstall the app from the device. Then
You can download all the versions of the DJI go app at apkmirror.
Then you need to enable installation from unknown sources on your device
And also disable auto updates in play market.
Fly safe.
Alex.
2018-9-2
Wolferl
Flight distance : 23793 ft
Austria
Difficult to tell...look here, maybe that helps:
http://www.phantomhelp.com/Tips/install-dji-go-on-an-android-tabletphone-step-by-step-guide.31
It is possible that you have too many apps running on your phone, that eats up RAM, and the DJI Go4 app is quite a bit "resource hungry".
I'd recommend to use the version 4.1.15 on Android devices.
Cheers,
Wolferl
2018-9-3
DJI Paladin
Flight distance : 318 ft
Sorry for all the trouble. Please make sure to back up your files and sync your flight records and then reinstall the APP. Kindly close all the background APPs  and make sure only DJI Go 4 APP is running on your phone. May I know what is the android version of your mobile device? Do you have a different  phone/tablet that you can use to isolate the issue? You can check the recommended devices below. Thanks for your support.
2018-9-4
Hakan81
Turkey
Wolferl Posted at 2018-9-3 00:47
I reset my phone to factory default, but still can not open v4.1.15, same error, what should I do now :s
2018-9-4
Wolferl
Hm, too bad. It looks like you need a new phone, one of the supported models pereferably...
Maybe get a used Samsung Galaxy S5 from ebay or so.
Cheers,
Wolferl
2018-9-4
Jos A
Flight distance : 73209 ft
you need also free space on your internal memory card!, also you must set permission to use unknown sources to install a downloaded app.
2018-9-5
Hakan81
Turkey
Wolferl Posted at 2018-9-4 23:28
but how can i install and use v 4.1.3 ?
2018-9-5
Hakan81
Turkey
Jos A Posted at 2018-9-5 00:10
i can install and use v 4.1.3 , but other versions do not wotk
2018-9-5
Jos A
What error does your phone gave when you installed  the 4.1.15?
2018-9-5
Jos A
https://www.apkmirror.com/apk/dj ... o-4-4-1-15-release/
you need android 4.4 and higher
2018-9-5
Hakan81
Turkey
Jos A Posted at 2018-9-5 00:58
Unfortunately DJI GO has stopped working (first message of this topic)
2018-9-5
Hakan81
Turkey
Jos A Posted at 2018-9-5 01:04
https://www.apkmirror.com/apk/dji-technology-co-ltd/dji-go-4/dji-go-4-4-1-15-release/
my phone version is android 4.4.2
2018-9-5
Jos A
Hakan81 Posted at 2018-9-5 01:07
reguest you try again, uninstall old app and delete also the dji folder on your phone.
then install 4.1.15
2018-9-5
Hakan81
Turkey
Jos A Posted at 2018-9-5 01:13
then install 4.1.15
tried over and over, but nothings changed.
same error after trying to open v 4.1.15
Interestingly, after connecting AC and RC , and  opening v4.1.3 dji go 4, it says ''latest firmware'' on the screen..
2018-9-5
Wolferl
Hakan81 Posted at 2018-9-5 02:41
"Firmware" is something different than "app version".
Cheers,
Wolferl
2018-9-5
Hakan81
Turkey
Wolferl Posted at 2018-9-5 02:50
Cheers,
ok, i noticed that
2018-9-5
Hakan81
Turkey
if i plug my phone through USB i can not see DJI folder on my PC ,  but same time i can see DJI folder with file manager on my phone
some evil forces are following me
2018-9-5
