djiuser_kUDbVO4wptG9
Flight distance : 23428 ft
I have been doing some testing in a workshop which is constructed from 6" thick concrete walls and an insulated tin roof. So,effectively a farady cage once all electrical,equipment was switched off. So,here is the sequence of what i did and what I found. It might explain why only some are seeing this.
1. Power on app, remote and mavic2 slowly and in that order, all other electrical equipment off.
2. I slowly switched on some light bulbs, TV screen, fridge etc, and all remained good. So i took the remote for a drive in car and lost connection about 200m away. When I reconnected i returned to the concrete room, and status read GOOD. I was monitoring and at no point did thd radio quality status read POOR before loosing signal.
3. Back in the concrete room I switched on my Dell XPS laptop and straight away it changed to the POOR radio status.
4. I switched off the laptop and waited 5 mins but the status did not change back to GOOD.
5. I tried restarting the app and the controller separately and then together, however the POOR status remained.
6. Finally I restarted the mavic and just before the status lights on the drone turned to flashing green, the Radio Quality updated to GOOD.
I repeated the above twice with the same results and then a third time with a devolo wifi access point, again same results.
This is suggesting that the interference is registered and the message displayed, tis message just does not update until the drone is reset.
I will do some more tests tomorrow, actually flying and see what happens, but staying away from all strong wifi signals for the full duration.
There were quite a few more tests, but the only way I could get the status to change from POOR to GOOD without a mavic2 reset, was to,manually change between 5ghz and 2.4ghz. Changing the channel within 5 or 2.4 did not work eventhough you could clearly see the manual chanel had no interference.
It would also seem like there is some sort of interference signal averaging to trigger a warning, as the longer I maintain good signal, the longer it took to trigger the POOR status by manually selecting a noisy channel.
That live graph is an incredibly useful diagnostic tool.
