Jgeeves Posted at 2018-9-7 04:51
Thanks Mindy, I checked all the axis before use and they all said excellent.
You can see in the video the problem surely this isnt just caused by having bad balance? what do you think? This is trying to acheive the 360 roll.
Hi Jason, thanks for the video, please try to tilt the device 45° to the left or right, then check if the Power value of all motors in Parameters Settings are within the range of +/-5. If not, please balance again.
For the Roll 360°, please make sure the settings are correct.
1. In the Ronin app, go to “Configuration”---”Control Settings”--- “Channels”, set CH3 to “Roll” and set the rest channels to N/A.
2. Use the Ronin-S with Flashlight mode.
3. Push the joystick left or right (which is the CH3) to enable the axis to make 360 turn.
Here is the tutorial video for your reference: https://www.skypixel.com/videos/ronin-s-roll-360-mode |
