Jakab Gipsz
Hungary
Lamplighter55 Posted at 2018-9-9 08:39
I think one has to accept that the Spark has a limited range (in the UK/EU max 500 metres from RC). So as long as you are within that distance and effectively in VLOS you should be able to manually fly the Spark to a safe area to land. It is a limitation but also helpful in these situations. GPS satellites can be disturbed unevenly across the sky at any given time. For example even though is shows that 14 sats are visible you might find that a significant number are clustered in one area of the sky and say only a couple are off in another area and say down near the horizon. What this means is that the drone cannot get a solid fix of position int 3D space and then losses concurrence for orientation with the single onboard compass - so then drops into ATTI mode. For suggestions check your wind for direction and always fly into the wind on your out-bound leg of your flight, so if it drops into ATTI mode you will at least have the chance of the Spark being pushed back towards you rather than ever further and further away! Also lower your height as wind speed increases with height. Use UAV Forecast app on your phone to check in advance what the wind profile will be in your area of flight.
This is all true and correct, but unfortunately the ATTI mode occurs unexpectedly and there is no time to assess the situation. You are busy taking a nice shot when you get alarms. There are a lot of seemingly unburned pop-up windows disrupting. Then you have to find out where the drone is? But as long as you tried to interpret the bugs, it was already started and you look up where it was, it is not there anymore. You are stressed and struggling to find out where you are, where you are going and where your front is, while you still do not understand what is happening.
You may not be prepared for this. I do not think a buyer of such a commercial drone has to do pilots training.
The DJI is nowhere to warn you enough about how to do so. It emphasizes its advanced flight system, and if it is a problem, it automatically flies home.
The well-flying pilot of the expensive drone gets a redundant flight controller (IMU compass), and an amateur who does not fly, gets an IMU, a compass that is unreliable.
Of course, it's a good thing to practice flying in ATTI mode, why not switch, like the Phantom and Inspire remote controls?
The option in the firmware there is just not got a separate button. By changing a parameter (DJI assistant 2 developer mode), you can change the Sport button to the ATTI button. And if you set it to FARM mode, you get ATTI mode with RTH.
So switches the switch to ATTI, but if you feel you can not control it, press the RTH button and go home.
Cheers! |
