rwynant V1
Flight distance : 4842277 ft
FlyLowandSlow Posted at 2018-10-3 09:38
Do you mean it will take more time? I have a multi charger like the one you linked but I would like to know how the DJI charger operates as i use that when i travel.
Sorry, BOTH at the same time........will take far less time to charge ( stock power supply )
Than if you first charge the battery, and then charge the RC
I do use the stock power supply to charge BOTH a battery and the RC at the same time....BUT, I also put a fan on the power supply as it WILL get hotter than charging 1 at a time.
The iPad and a Battery......the iPad draws far less than the flight battery.
Randy
