FlyDK
Flight distance : 1636286 ft
Denmark
Zorrr2@aol.com Posted at 2018-10-9 08:46
Sorry . . was not my intention . . I had previously recorded this above and all I did was copied it down for you . . no . . mean intention was meant at all. Sorry if you took it that way.
Apology accepted. But it's still pointless to move backwards trying to solve your own video problems. You previously wrote to me that you had made new recordings, with the settings I suggested and that it had helped. Therefore, it makes no sense to show an older video, as well as the settings it was taken with. I knew those already.
I repeat: The first settings you showed are not optimal for good recordings, and those I suggested helped, as you mentioned it yourself. If you want more attempts on help from me, show a new video, and indicate the settings with which you have recorded it. Also indicate which SD card you have used for the new video, and if you have used ND filter, and if so, which one. |
