DJI Assistant on macOS Mojave
5501 16 2018-10-20
szh
Flight distance : 252139 ft
Does DJI Assistant 2 v1.2.4 work correctly on macOS Mojave?  Does DJI have a statement on this?
Can any users confirm that they have successfully connected to the drone through USB on Mojave?
I would like to make sure that DJI Assistant will not break before updating macOS. There are multiple reports on this forum that it does not work.
2018-10-20
DJI Natalia
Hi, I appreciate your time bringing this query to us. In regards to the compatibility of the latest macOS Mojave to the DJI Assistant 2, I'll forward this concern to our Senior engineer for further clarification. I'll get back to you once I have the update. Thanks for your understanding.
2018-10-20
szh
Thanks for looking into this Natalia!
I'd also appreciate comments from fellow users: has anyone used this software successfully on Mojave?
2018-10-22
Hi szh, thanks for your patience, we have verified with our engineers that this system is compatible with DJI Assistant 2, it is recommended to re-install the DJI Assistant 2, if possible, please record the installation process and provide us the video for further assistance, thanks for your understanding.
2018-10-23
szh
Thank you Mindy!
2018-10-23
chuzonet
Hello good day,
I'm a Mac user and I can not make it work DJI Assistant with Macos Mojave.
Greetings and forgiveness for writing in this post
2018-10-27
chuzonet Posted at 2018-10-27 23:38
Hello good day,
Hi there, sorry to hear that,  as I posted in 4#, this system is compatible with DJI Assistant 2, it is recommended to re-install the DJI Assistant 2, if possible, please record the installation process and provide us the video for further assistance (please upload to YouTube and post the link here), thank you.
2018-10-28
sparkies
So, this works for me, up to a point. It can see the rc/ac but cannot see the aircraft logs I have a Mavic 2 zoom
2018-10-28
Asulliv54
Yes it does work I just bought a Maverick Pro and used Mac OS using Mojave to install updates using DJI Assistant 2 thru USB to remote & drone
2018-11-2
DJIJAKOB
Flight distance : 740577 ft
Norway
All Assistant versions that I use currently work with my iMac (late 2017) and MacBook Pro (early 2018) that are both running OS X Mojave. But as #4 says it is recommended to reinstall DJI Assistant 2.
2018-11-3
fansf5d8a68a
Flight distance : 166047 ft
Norway
I can't get it to work! I've deleted the old one, reinstalled but nothing happens. It only shows a DJi USB plugin screen.
I need to fix my drone, because I have cameraissues which is posted here: https://forum.dji.com/forum.php?mod=viewthread&tid=184361 and want to try to reset everything.
This is filmed in d-log with 0-0-0 settings, 1080p 60fps 1/1600s iso 100:
https://www.dropbox.com/s/d5zkrsfq7on34e0/trim.mov
And it is not shot through glass or a window, I'm on the balcony outside.
2019-3-21
fabrysious
I'm experiencing the same issues
2019-4-29
Niederrheiner
Hi Guys,
using  latest version of MacBookAir / German / latest OS-Update installed
and no problems with DJI Assistent (latest Download from DJI global Site)
Updates / Downgrades went well without any issues, problems or brick...
Connected M2P with the provided USB adapter cable and a Novoo USBC Splitter...
From mpov stable and reliable...
Cheers,
Manuel
2019-4-30
UKguy
Hi
Macbook Pro 10.14 + Mavic Pro (original V1) + DJI Assitant 2 = . Doesn't seem to work. installer says its completed but the app is missing. The Horndis driver which it installs at the asme time doesnt not sya it supports 10.14. Is this the problem? How can I reset my RC for my Mavic Pro without a functioning DJI assitant app?
2020-2-1
BiDi
Flight distance : 16214 ft
I'm stuck with this message when trying to install on MacBook Pro/Mojave. Only option is to kill the insall process.
2020-7-17
bill81
Has a solution been found for the Mojave install issues? I'm running 10.14.5 and each time Assistant 2 says it is installed it fails to appear in installed applications. Very frustrating given I need to check battery firmware on the Inspire2 and cannot do this on DJI Go4...come on DJI!
2020-8-18
djiuser_9a77gn16YtLB
Indonesia
Hello, why DJI assistant 2 (FPV) doesn't have file version installer ? I'm on Mojave, and it won't open, and this is very annoying, because theres no answer for this.
2022-4-10
