Sato Zoom 2
Flight distance : 3172890 ft
DJI Tony Posted at 2018-10-30 08:49
Hi, thanks for the prompt reply. I would recommend trying to set the resolution of your monitor into a default mode and it would be better if you could possibly use a screen that has a 14inch size of the monitor or higher to see if there will be changes. Please keep us posted on the latest progress. Thank you.
Thanks Tony, I got it to work, I had to set Windows to allow unsigned drivers. I could never get past the tutorial screens to even begin the calibration process. Once I got the process started it worked fine on my 17" monitor in standard resolution.........now to see if the VPS errors go away........ |
