smcbrearty
Thank God DJI is starting to listen to it customers!!! I know that there have been some issues dealing with support but finally getting a real DJI employee to answer and work with us is freaken amazing!!!
On this topic of being able to charge more then one battery at a time, I fly with a minimum of 6 charge batteries at a location. You can imagine how much of a pain in the @$$ it was to try and charge 6 batteries over night (set the alarm clock for 1 hour and 45 minute intervals, wife was not a happy camper). I do not know much about the batteries themselves, all this talk about 4.2v charging at 12 amps blah blah blah is alien to me. Like a lot of us newbies I started searching the internet for a charger that would be able to charge multiple batteries at once. Long story short i DO NOT RECOMMEND buying a multi charger unless it has been designed for and by DJI. I purchase a "charging bar" that you can plug 3 batteries into and then use your stock charger to charge with.
First thing, the batteries charged at the same rate as they had before, meaning it took close to 6 hours to charge the 3 batteries (I have since learned that if you want to charge 3 batteries at once you need to have a charger that is 15 amps[or so the internet says]). 2 of the batteries charged just fine, the third batter almost got fried, it only charged to 75%, I was so scared that the battery would not be recoverable, but luckily after 4 regular charging cycles it was was able to be charged back to 98%. |
