Aardvark
Flight distance : 384432 ft
That is the calibration for the goggles own IMU you're seeing, not the aircrafts. All aircraft calibrations are done using DJI Go 4, or Assistant 2 for VPS. By calibrating the goggles IMU you are giving it a reference as to what represents level. So when you move your head about the sensors can react accordingly.
If you are attempting to fly using goggles only, then you will find a limit of 30 metre altitude and 50 metre radius limitation (similar to beginner mode) if you are not using a display device running a 'logged into account' DJI Go 4 App'. |
