Geebax
Bashy Posted at 3-7 20:23
That is what i would do, but its not always the best option and could end up costing you more though, especially off of facebook, i am so wary of FB market place, normally there is something wrong with the items if not at 1st obvious, last couple of dearer things i bought have been lemons, 1 was a 80 quid Samsung home cinema, it overheats, says fan is no good, i even replaced the fan and still the same so i put a small 40mm fan behind it and thats resolved now, the other was the Samsung Smartthings kit, 2 senors report battery low even when the batteries are brand new (i replaced them) and the more expensive plug was not in the box. Buying online 2nd user is always a big gamble to be honest.
You didnt answer my question though re what would happen if a 2amp is used, would it still work but at a slower charge rate or not work at all?
'You didnt answer my question though re what would happen if a 2amp is used, would it still work but at a slower charge rate or not work at all?'
Sorry, most likely it would not work at all. It may even smoke the wall wart.
