RobWest
Flight distance : 589633 ft
RobWest Posted at 4-24 09:22
Hi DJI Gamora. I did update the Aircraft first, that went absolutely fine.
These are the screenshots from DJI Go 4, the first one shows the firmware version for the RC as 01.00.0300, the second one shows the info screen that reports that the Overall Status is 'Normal (Latest Firmware)'.
When updating using DJI Assistant 2 it gets to Downloading 100% and then immediately reports that the device has been upgraded. This happens on both computers that I tried. I know that normally it will be several minutes after the download finishes before it reports as successfully updated and there should be a message on the RC to say that it is updating, neither of these things happened.
I also tried refreshing the RC firmware with v01.00.0300, but that also just showed that it was successfully updated as soon as the download had finished, so I suspect that it hadn't run the refresh. |
