cutis
Flight distance : 1695351 ft
Synaptic Storm Posted at 6-29 20:55
@cutis:
Thank you for confirming the problem and explaining your solution. It sounds as though it's important to plan for a permanent communications failure before every flight. This is unfortunate, but as long as there's a strong GPS signal, your solution makes sense.
No, loose as it insinuates fault, that junction, is normal, for if not, video feed would compromise.
Dont take off, just jostle that junction, to affirm video feed not compromised.
My s8 samsung phone usbC receptacle mates snug versus the rc side of provided 4cm flat cable. Nevertheless rc side is not as snug but video feed not compromise by jostling rc junction.
No, cycle rc power does not reconnect bird.
Normal recovery is reconnect since bird autonomy homing shortens separation favoring reconnect.
However, when closer proximity and still refusal reconnect, attempt backing out of apk (application in android phone used to fly). Purge stack of it, recents button.
If bird reconnects apk autolaunches itself, else manually. Wait server chks, wait blue banner "go fly" click banner, video feed should be.
If no reconnect cycling apk, big trouble, so watch
ears audio approaching rth, as there may be issues obstruct had launchpoint been selected indecent.
Check your elex on your person, |
