Inspire 2 - X5s gimbal disconnected
827 2 2019-7-18
SteveDeNeef
Flight distance : 68986 ft
So my Inspire 2 was working fine, today I had to activate the Prores license for an upcoming job, that's when the problems started. At first the activation kept failing, after an update to the latest firmware it finally worked. Then all of a sudden the camera view went half black, then nothing... Turned everything off and powered on again, the gimbal did its usual thing but there is no image and it says gimbal is disconnected.... The AC can still take off but there just no connection to the camera. Anybody had this issue before and found any solutions?
2019-7-18
AntDX316
Flight distance : 3394731 ft
What job are you doing w/ the Inspire 2?
2019-7-22
GeoffG
Flight distance : 810082 ft
Do you get any messages like "Image Transmission Loss - RTH"?  Does the bayonet ring lock properly (with a click).  Try wagging the cables that come from the gimbal around.around
2019-7-30
