A J
Flight distance : 13877205 ft
DMS Photo Posted at 7-31 10:56
I know the precise altitude above sea level because I am smart enough to know how to read a topographic map. And your presumption that I did not know what the TOP ALTITUDE number referenced...max altitude at take off...is incorrect.
Nevertheless, I thank you for your input regarding the insignificance of the erroneous data. Sounds like it is something to be ignored if it has no bearing on the actual safe operation of the drone.
It has no bearing - I've taken off at precisely the same location with many different drones and that reading varies considerably - my Mavic 2 Pro, for example, recorded it as 309.6' where my Mavic Platinum noted the same location as nearly 1,000' ASL. Neither drone had ever crashed, flown away or experienced any glitches in flight and the altitude reading in the app during flight has always been accurate with every DJI drone I have owned hence, it's not of any significance. The front screen data is merely for personal reference. The ASL reading is not assessed in any other area of the app for day-to-day flying. |
