Can't connect A7 to ronin SC with cable
12Next >
43611 43 2019-8-7
Divil22
Hello everybody. I have a problem with my camera (Sony A7) or with my Ronin-SC. If I use the included cable that runs from the ronin to my camera, my A7 remains to say "check the connected device" with a black screen that prevents me from filming. I have already tried to use other USB settings but have not yet found a solution yet. Does anyone know a solution? Thank you for reading
2019-8-7
Peter von Frosta
Flight distance : 39659 ft
Did you turn on the Ronin first?
2019-8-7
Divil22
Peter von Frosta Posted at 8-7 06:13
I powered first the ronin and then the A7. But have tried all kind of different orders
2019-8-8
Divil22
2019-8-8
Peter von Frosta
Which Firmware Version is installed (on the Sony)?
2019-8-8
Divil22
Peter von Frosta Posted at 8-8 21:41
The latest version (Ver.3.20)
2019-8-9
Sprut
Flight distance : 153406 ft
Russia
Try to flip the cable you plug into the ronin
2019-8-9
Divil22
Sprut Posted at 8-9 11:56
That does not work
2019-8-12
djiuser_UWYyzUny3y1T
Hi.. Sony A7RII is not connecting to Ronin SC. I have set the USB connection to PC Remote and also Remote Control is on. Cable I used is Multi to Sony.
2019-8-13
Divil22
djiuser_UWYyzUny3y1T Posted at 8-13 10:42
Hi  i have the same. Such a bummer
2019-8-13
Basab
Divil22 Posted at 8-13 11:08
Hi..How are approaching the issue? Are talking with DJI support?
2019-8-13
eddiepapi
Flight distance : 94865 ft
Try it with remote control off.
2019-8-15
Divil22
Basab Posted at 8-13 19:04
Not yet. I don't have the time to write an email and live chat doesn't help me because it is a professional product
2019-8-15
Divil22
eddiepapi Posted at 8-15 10:45
Doesn't work
2019-8-15
fansadf34918
Switzerland
Me too. Sony A7RII is not connecting to Ronin SC. I have set the USB connection to PC Remote and also Remote Control is on. Cable I used is Multi to Sony. What to do please????????
2019-12-22
fansadf34918
Switzerland
IS GOOD NOW
2019-12-23
djiuser_AbQvr2p0tArn
fansadf34918 Posted at 12-23 11:36
IS GOOD NOW
I am having this issue. What fixed it for you?
2019-12-31
hummels
I have exactly the same problem: camera is Sony A7Riii. Latest Software Vers. 3.10.
Firmware update for the Ronin SC combo is made. Cable from Ronin SC to the Sony is in the right position and right direction.
But I have the same message on the Sony: "Check the connected device".
@fansadf: How do you solve the problem?
2020-1-2
djiuser_uQ8N6tLMpY4J
fansadf34918 Posted at 2019-12-23 11:36
IS GOOD NOW
I have the Sony a7rii and for 12 hours I’ve tried every different alternative I can think of to get the record button on the ronin sc to work, it just won’t work , can anyone help?
2020-1-23
nightsoundsmedi
South Korea
Hello,
Did anyone solve this issue for them selfs? I’m experiencing the same problems with my Sony a7iii and I just can’t get it to work...
2020-3-13
Jeremy J
I'm looking for the same answers, a7iii and ronin sc (latest firmware)
any configuration of usb C and/or multi cable has yet to work.
2020-4-4
pjaustin21
Make sure that on the Network 1 menu "ctrl w/ smartphone" is set to off.
2020-5-1
djiuser_VWNca5ZUUMLT
Go to menu, then to setup.  On page 4 you see usb connection, change that to pc remote. This worked for me
2020-5-5
djiuser_Wo31ytRS81Sj
Hi guys, THIS IS THE SOLUTION: Make sure that the end of the cable that goes into the gimbal IS FULLY PLUGGED IN. It has sort of two stages: The first engages and holds the cable in place, which is what all beginners do (i did the same) but which is not actually fully inserted and thus the connection to the gimbal and the camera does not work.
HOWEVER if you just gently apply a bit more pressure on the end that goes into the gimbal, you'll notice that the connector sort of plunges one step further into the slot, locking it in place even more firmly. That is this "second stage". Once you've got it fully inserted that way, the connection between gimbal and camera (and all of its buttons) starts to work instantly.
2020-5-7
By the way : Control with Smartphone does NOT have to be off for the connection between gimbal and phone to work. In fact, if say you're on Sony A7III and you want to use your phone as a field monitor, you can achieve this by turning on Wifi, Bluetooth and Control with Smartphone, then connecting to the Sony Imaging Edge app and the use it with the gimbal simultaneously.
All of the buttons (mainly just the recording button of course) on the gimbal is still going to work and your phone can communicate to the camera to wirelessly transmit the image using Wifi. It's pretty neat.
2020-5-7
Highranger
I cannot either. After 2 months have given up! Even tried the other USB C cable that comes when you buy the focus motor option.
Yes I have turned on Ronin then Camera.
Yes I have selected 'PC remote' and turned off 'Control w/Smartphone'.
I either get the message "Check the connected device" on the camera or else I get no message and the camera is deaf to the record button on the Ronin. I have also reversed the cable.
It has never worked since I bought the Ronin. Using Sony A7r3 with current FW version 3.10.
2020-6-11
ggFF
1) check your cam + cable with another brands gimbal 2) check the RoninSC with another cam / cable combi to find out about the problem.
2020-6-16
Sebastian1993
I have the same issue... is it possible to fix it? I see on youtube that some ppl doesnt have the issue b using same equipment as me.
2020-6-23
Billy Amann
I just turned control with smartphone off and then went into USB connections and made sure it was set to PC remote. Solved the issues instantly for me.
2020-11-22
fans140d66fb
I also have this problem with the sony a7RIII
Is there any fix for this already! I hate DJI for it not fixing this!
2020-11-26
djiuser_y193RxKmnTOY
Kuwait
So I had the same problem and fixed it by turning the PC Remote on.
I have sony a7s iii and everything was perfect.
2020-12-10
Francis Bau
Had the same problem. The multi to sony cable didnt work and probably bad. I used the usb c to camera cable and used an adapter on one end to fit sony. The 90 degree side goes in the ronin sc and the straight side on the camera. If i try flip it it doesnt work.
Set on movie mode
Usb connection on Pc remote
Sony a7s and sony a7rii and sony a7ii all working that way.
Just sharing.
2021-1-17
-Samas-
New Zealand
fans140d66fb Posted at 2020-11-26 04:58
I was having the same problem for about an hour, then I realized there are two cables that look pretty much the same, one is called Type C to micro usb and one is called type C to Multi. The micro cable will go in, but only half way and will still charge the camera. The multi cable worked immediately
2021-3-8
amberanywhere
I found a solution:
for Sony A7S iii to Ronin SC2
Menu > Network > 1. Transfer/Remote > Ctrl w/Smartphone > OFF
Menu > Network > 1. Transfer/Remote > PC Remote Function > ON
Cable USB-C to USB-C
connect camera to the USB-C port on Ronin that is on the same plane as the quick release plate and has the camera icon.
Turn on Ronin FIRST
Turn on Camera SECOND
Hope this helps
2022-3-12
fans0a1f2368
Hi I've tried everything on the previous threads and nothing works. I keep getting this message,
Cannot select the USB connection mode during USB cable connection with this setting.
I'm not sure what to do or what setting to change I'm on movie and I've tried Network options and nothing seems to work and everything that you had previous is done.
I even remove the USB cables and still get that message
2022-3-28
Hebbare Manikantha Rao
India
The DJI Ronin S Cable not working with my Sony Alpha VII M4 Camera.
Please suggest the settings  to me #yesreach
2022-5-23
dergachoff
United Arab Emirates
amberanywhere Posted at 2022-3-12 19:15
I found a solution:
Thanks so much for this reply! Even had to register to post it.
For those who get there through google search like me:
I have A7C and RS3 Mini. And couldn't figure how to make the connection for half an hour. Tried everything, was ready to hard reset the camera and then go to the service center. Turns out all this time I was plugging in the wrong port on gimbal. Don't plug it into handle – it's a charging only port. PLUG IT NEAR THE TILT AXIS in the usb-c port with camera icon and RSS text.
2023-2-10
djiuser_n8sGsXYNbDb6
dergachoff Posted at 2-10 09:53
After about 2 long hours of wanting to find the nearest building and dive off of it. This is the only solution that helped. My dumbass was plugging it into the charger port. Didn't even know there was another port. I owe you a round of beers. Thank you
2023-2-22
djiuser_yLid9AXNn8cF
djiuser_Wo31ytRS81Sj Posted at 2020-5-7 12:18
This was it for me!! THANKS SO SO SO MUCH!!!
2023-3-21
djiuser_WSBDCabI5u3V
Billy Amann Posted at 2020-11-22 12:27
THIS WORKED FOR ME. Thank you!!!
2023-4-13
12Next >
