jarex
Flight distance : 661096 ft
Poland
Hi, if desired panorama has 360 degrees horizontally for 10mm APS-C app does 4 shots. It would be ok because 4 x 109 (fov of lens) = 436 and it's 360 with 21% overlap. Overlap rather small but adjusting overlap missing after update. Thats minor problem. Major is starting and ending photo, its the same point- the two same shots same 109 degree. And next two shots are insufficent to cover rest of panorama (360-109= 251 degrees) so we can't stitch photos.
Next point- update expand vertical angle of panorama, now is from -45 to 90 degrees. Interested but app does too many shots (four) in 90 degree position, two is enough ( for 10mm APS-C). More shots is needed in horizontal position. Panorama strategy in ronin app should be recalculated.
