Ken Storm
Flight distance : 178583 ft
Before you take off, inspect your props make sure they are not chipped or bent. Then after take off, bring it down to a few feet and visually check the spinning props, looks for ones that look like they are not spinning true, easier to spot when you compare them against each other. Try and do this in calm-ish winds. So it sits nicely in the air. |
