Travel carry on with the Inspire Case
1638 9 2015-6-11
5280Fly
Hello,
I am planing to take my Inspire 1 on a trip with me and wanted to see if there was any issues with the case that comes with the Inspire 1 as carry on, on the major airlines.
It seems that the case might be technocracy 4 inches too wide.
According to most of the Major Airlines the allowed max carry on is on average 22x14x9 (ebags guide).
The Inspire case is 23x20x10, which is just over the carry on sizes.
Just looking for other peoples experiences with the case and traveling with in the US.
Thanks
2015-6-11
MJDMike
There are many posts on this forum about that.  You might try to search them up.
The bottom line is that it's dependent on the airline and whether they notice you at the gate or not.  If you do get on, great.  If not, you will be forced to check an expensive piece of electronic gear in a less-than-adequate protective case.
I bought a case and check mine.
-Mike
2015-6-12
GB44
Flight distance : 343848 ft
There have been lots of posts on this.  Try looking for some earlier posts, you may find the exact airlines that it will fit into the overhead storage etc.,
2015-6-12
dentin11
Flight distance : 155646 ft
What about the number of Batteries you can carry on board?
2015-6-12
rsghowellnj
Flight distance : 508255 ft
dentin11 Posted at 2015-6-12 22:25
You can bring as many TB47s on board but you are limited to 2 x TB48s in your carryon.  This is the rules flying domestically in the USA.  Not sure outside the USA.
2015-6-12
dentin11
thanks!   And how many P3 batteries,  4480Ah- 15.2 V?
2015-6-12
rsghowellnj
dentin11 Posted at 2015-6-13 10:56
I honestly don't know.
2015-6-13
FlyGuy
Flight distance : 106483 ft
Belgium
Since a few days ago in Europe the new guidelines for handluggage are : 55 x 40 x 20.
Before that every airline had it's own guidelines. Now they are the same for every country and company.
For batteries, I suggest you contact the company you are flying with. I'm guessing there will be differences between them.
2015-6-13
Pgale
Flight distance : 275207 ft
FlyGuy Posted at 2015-6-14 14:48
Before that ev ...
Yes there are a lot of differences in the number of batteries you can carry on with different airlines. For instance, in the UK and any other country for a British Airways flight, they limit the number of sub 100W/hr batteries (I.e. TB47's) to 4 and sub 160W/hr batteries to 2. They don't make it clear if you can carry 4 TB47 AND 2 TB48's together though, although I read it as if you can.
Important to be aware of, particularly if you fly a route using different airlines or if your itinerary/carrier is likely to change.
2015-6-14
leoamartinez
Flight distance : 1602986 ft
Dominican Republic
Once i went from SDQ to MIA and i told them that it was a very expensive photograph equipment, they authorize that the case went into the plane with me, when i got in the plane, they kept the case in a crew closet, the inspire was very well placed
2015-6-14
