Flygmaskin
Flight distance : 70719 ft
Thought I post this, hoping it will help either me or someone else.
Just got a Spark back from repair after a minor crash (please see this thread)
The AC I got, seems to be the same as I sent in. atleast the S/N is the same, both on the styrofoam case and on the AC itself. Echanged parts were: 3x motors, 1x fan, 1x Gimbal roll & pitch axis module, 1x mid-frame and 1x main core processor board. Service center noted 'No GPS-Issue found during test'.
After activation I aimed to test it out, to see if it worked as it should. Unfortunately it didn't. I started it in beginner mode, and it wouldn't take off because it shows 'No GPS'. The satellites are there, but it appears no connection/reception. I waited a long time to see if it would find any reception, but never did. I thought that the last place it had GPS connection in, should have been in the service center in the Netherlands. Atleast they said they performed a test flight. Thought that it could take some time for the AC to find it's new location.
Anyhow, even if it got good GPS, I wouldn't have taken off. It's picking up heavy compass interference, and this is in an area that really shouldn't have any metal close by.. I have tried in several different areas, I have made flights in those areas with this unit before. I probably will try more areas later today.
Having read a bit about compass calibration here and in different forums, I didn't perform any. I had a Spark which I almost lost because of compass errors, so I'm a bit worried that if I calibrate, the problem may still persist but won't be showing until mid-flight. Grateful for any input here.
I have wrote the same representative that handled the initial repair case, and explained the situation. No reply yet.
I'm not sure what would be best doing in this situation.. Try the standards (flash firmware, downgrade/upgrade, restore factory defaults, calibrate the compass in open area, try even more different locations to see if I get GPS-reception..) or just ship it back to DJI for evaluation.
Also, can someone tell me if I can view the entries from the black box? There is 5-7 entries there which I think have been made during service. If they performed flight tests, the logs might be there and it would be interesting to see how it performed.
I tried in some different ways, but no luck yet..
Kind of sad, after having the AC in the repair shop for almost two months, I get it back with these errors, problems it never had before..
This is what the Go4 app is telling me:
