BGA
Oh well, I was excited because I found a way to get direct developer support at DJI but, then, the results were not what I expected. Here is the bugs/feature requests I filled and the results so far:
Allow app to run on ChromeOS: Will be considered for future versions (I guess this was the best result I got but even this is just something that may or may not happen).
Programs in the DIY Lab do not respect fire mode selection: "Sorry that DJI RoboMaset S1 does not support infrared firing at present" followed by a suggestion to file a feature request. I will follow up on that.
Trying to use Python classes results in error: "Sorry that the DJI RoboMaster S1 python editor does not support class definitions at present"
Document ImageInfo class: "The data type of parameter "msg" is a list". No, it is not. They followed with the describtion of the detection info stuff that is a list indeed. Will try t follow up on this.
Loading "big"python program fails: Can not reproduce but tried on Android. I actually saw it in Windows. Will follow up on that.
Firing in autonomous mode does nothing: They say that for safety reasons firing gel beads in autonomous mode is not allowed. Then I followed up saying that it also is unable to fire IR shots. They replied with IR shots are not supported.
Not able to detect IR hits: They said currently the Robomaster S1 does not support programming the IR transmitters or receivers.
