rwynant V1
Flight distance : 4842277 ft
Hi Folks,
Anyone reading this it sure can be confusing!
Example: You leave home...go about 20 miles to a flying site where you need to manually UNLOCK the bird. You are now unlocked in the Authorization/NFZ. It doesn't show you
that there is a SWITCH turned ON in the "Unlocking License" section. This is located in the 3 dots, upper right of your screen.
Now, you go back home and try to fly.......with that UNlocking License turned on....you can't take off because the bird knows you are TOO FAR away from the unlocked area.
Go into the Unlocking License and turn off the switch. Bamm, you can fly!!
Good luck
Aerial Traffic www.aerialtraffic.us
Randy
