I have 3 problems: video, gps, rotation
899 5 2014-11-15
ppavel12
Flight distance : 527795 ft
Bulgaria
Hello. I have three problems:
1. Bad connection with satellites
2. Dji rotate left and right downhill
3. Parties flashes in the video, see link:http://youtu.be/uAFc7-TjnGk
2014-11-15
gil
Flight distance : 1379308 ft
"Dji rotate left and right downhill" -- do you mean the Phantom is yawing left and  right when you are descending?  From your video it looks like you're rapidly descending and that means you're falling into the unstable rotor wash air beneath the aircraft.  You can try adding a little right stick while you're descending (fly forward, backward, left or right so you're descending at an angle) or simply slow down your descent.
2014-11-15
ppavel12
Bulgaria
Not revolution, gently turning about 30 degrees left and right.
2014-11-15
dtburr
ppavel12@gmail. Posted at 2014-11-16 02:01
Have to recalibrated your compass in a good clear area?
2014-11-15
away-point
As mentioned, fast decents are unstable, but wind makes it worse.  Probably a lot of wind near that rock face.
It's very difficult to apply throttle input without accidentally adding some yaw.  One thing I do to avoid this is control the throttle by rolling the base of the stick, without touching the stick.  This completely avoids inputting unintended yaw.
Also, those rocks might be effecting your GPS by blocking line of sight.
2014-11-15
ppavel12
Bulgaria
these problems do not happen only in these frames and almost every putt as a photograph, this video is just an example.
2014-11-15
