GreenDayPR
Flight distance : 517087 ft
DJI Gamora Posted at 12-21 13:15
Hi, thank you for bringing this query to us. I will highly recommend to please make sure that the propellers are installed securely before each flight. Check if the screws on the propellers are tightened every after installation and every 30 hours of flight time. (approx. 60 flights). There is no need to perform a calibration if you are changing propellers.Hope this helps. Thank you for your support!
Check! Thanks so much for the quick response! |
