EFRPIC
Am I correct in assuming that you are actually asking about reading a card on your computer AFTER having flown and recorded? If that is the case there could be several issues:
1)If you turn off the aircraft before stopping a video recoding session, I have seen corrupted cards.
2)The actual SD card could be bad for a variety of reasons (bent taking it out, static discharge or just plain product failure)
3)The SD card you are using is not supported if it is over 64 and/or 128 depending on the aircraft.
There are programs that can recover SD cards if they are actually operational. More on that if you need it. |
