Burak C.
Flight distance : 21814 ft
Turkey
DirtPiler Posted at 12-23 12:28
The connector is in the picture above. The connector isn't broken It just came off the board. It needs to be re-soldered back. I took it to an electronic repair place but they said you need a special solder unit to attach it back.
Oh, I thought that it was broken or something and you wanted to solder a new one, sorry. It is not common that the solder just snaps out of its place, weird though. Since it is a SMD part it should be soldered with a heat gun and it should be handled by a experienced person. It is best to leave it to the DJI technical team. |
