BobWinNV
Flight distance : 284209 ft
Are you sure that your “standard USB” cable is a “standard “ cable and not a data only cable?
I would try another cable and also be careful with the orientation of the micro plug going into the RC. The correct orientation is shown on the RC next to the micro connector. The micro connector used on the RC is more of a rectangle then a trapezoid like mist micro connectors so it is possible to plug it in the wrong way some folks are reporting. |
