lannes
Flight distance : 4465 ft
Try connecting the RC (don't turn it on) to the PC, open DJI Assistant 2 , sign in if you need to, only then power on the RC
This may trigger a usb driver install
Try this method also with the AC, don't turn it on until the very last thing after the Assistant is open on your PC
Also in the device manager are you seeing a anything connected to the COM3 port, DJI uses this to connect via usb
If there is something else using this then there could be a conflict blocking the usb connection
Here is a picture of mine showing the COM 3 port being used by DJI when I have my MPP turned on and connected to the PC
