Burak C.
Flight distance : 21814 ft
Turkey
jonny007 Posted at 1-5 11:54
Lets say I have 3 batteries in the charging hub, battery 1 with 90%, battery 2 with 80% and battery 3 with 70% power level. Now I connect it to charge a powerbank, smartphone or what else. As I understand battery 3 will be discharged first ... to which level ... but not 0% = over discharged or ? If it is best to hold 40-65% I would have to keep watching the status leds until only 2 light up, then remove battery 3 because I don't want over discharge. Now for battery 2 and 1 the same ... very cumbersome. Would be good I place all batteries in the hub, let charge the connected device and finally ALL 3 batteries would have been discharged to an optimal level, e.g 45%. I always wonder where there is intelligence ... at the hub or the batteries...mmmh.
To my knowledge, it just discharges until 0%, since this is a smart battery, 0% is not overdischarge, i think 3.2V is 0%. A overdischarged battery is 3V which is dead. But as you said, swapping all batteries to maintain 40-65% for each battery is for storage which is the best. Because leaving battery empty and full is not good. Just make 0% battery if you will charge it soon. Otherwise storage percentage is fine. |
