DJI Stephen
Hello and good day #WoOkieE#. Thank you for reaching out and for the information you have shared with us. If your DJI Mavic Mini is the CE version, then you can fly it normally in CE, SRRC, and FCC countries and regions. In an unobstructed environment free of interference, the max image transmission distance is as follows:
If it is a CE country or region, the Mavic Mini’s max image transmission distance can reach 2 km in 2.4 GHz and 500 m in 5.8 GHz ( if supported by local regulations );
If it is an SRRC or FCC country or region, the Mavic Mini’s max image transmission distance can reach 2 km in 2.4 GHz and 500 m in 5.8 GHz.
In addition, when the CE aircraft enters a country or region where 5.8 GHz is restricted, such as Japan, Russia, Israel, Ukraine, and Kazakhstan, DJI Fly will ban the 5.8 GHz according to the country code that has been identified, and therefore users can only choose 2.4 GHz. Please follow the local regulations when using the aircraft. Thank you and fly safe always. |
