Mavic Mini Drop Problem
923 1 2020-1-19
Bidrone
Flight distance : 19682 ft
Turkey
On fast landings, the Mavic Mini has a falling problem.When the Quickshot dronie and rocket modes are completed, the Mavic Mini loses control and falls on the turn. In manual use, it moves out of control in fast downward movements. I didn't experience a slow fall with the device. Looking at Airdata data, the battery starts to give 67% error (Not Enough Force / ESC Error). I changed and tried the battery. Again after 50% it gives the same error. There are a lot of users who are having problems. What will we do as a solution?
( I have changed propellers. Version 400 and application 1.0.6. There are no problems or warnings. GPS 10 and above. Calibrated. Forest protectors are installed.phone Iphone 7. flight mode C )
Flight time
Altitude
Home DistTypeNotification
A00m 00s0.0 ft0 ftMode[url=]Mode changed to Motors_Started[/url]
B00m 00s0.0 ft1 ftTip[url=]Setting new Return-To-Home altitude to 60m (197 ft). Data Recorder File Index is 65. Setting new Maximum Flight Altitude to 120m (394 ft)[/url]
C00m 01s0.0 ft1 ftMode[url=]Mode changed to Assisted_Takeoff[/url]
D00m 03s0.0 ft1 ftMode[url=]Mode changed to Tripod[/url]
E00m 19s2.6 ft4 ftTip[url=]Setting new Maximum Flight Altitude to 30m (98 ft)[/url]
01m 28s0.0 ft17 ft
[url=]90% Battery[/url]
02m 06s95.8 ft64 ft
[url=]87% Battery at maximum distance[/url]
03m 30s1.0 ft15 ft
[url=]80% Battery[/url]
F04m 14s4.6 ft13 ftMode[url=]Mode changed to Quick_Shot[/url]
G04m 39s5.9 ft15 ftMode[url=]Mode changed to Tripod[/url]
H04m 59s7.5 ft19 ftMode[url=]Mode changed to Quick_Shot[/url]
I05m 21s8.2 ft18 ftMode[url=]Mode changed to Tripod[/url]
05m 30s7.9 ft18 ft
[url=]70% Battery[/url]
J06m 01s17.1 ft18 ftMode[url=]Mode changed to Quick_Shot[/url]
K06m 21s17.7 ft19 ftMode[url=]Mode changed to Tripod[/url]
07m 21s11.2 ft26 ft
[url=]60% Battery[/url]
L07m 39s10.2 ft24 ftMode[url=]Mode changed to Quick_Shot[/url]
M08m 00s9.2 ft39 ftMode[url=]Mode changed to Tripod[/url]
N08m 34s11.5 ft36 ftMode[url=]Mode changed to Quick_Shot[/url]
O09m 05s10.8 ft35 ftMode[url=]Mode changed to Tripod[/url]
09m 15s11.8 ft36 ft
[url=]50% Battery[/url]
P09m 49s10.8 ft19 ftWarning[url=]Not Enough Force/ESC Error (repeated 50 times)[/url]
Q09m 54s8.5 ft20 ftWarning[url=]Not Enough Force/ESC Error (repeated 30 times)[/url]
R10m 19s6.6 ft20 ftMode[url=]Mode changed to Quick_Shot[/url]
S10m 48s9.2 ft6 ftMode[url=]Mode changed to Tripod[/url]
T10m 51s5.6 ft5 ftWarning[url=]Not Enough Force/ESC Error (repeated 18 times)[/url]
11m 06s5.9 ft25 ft
[url=]40% Battery[/url]
U11m 30s4.6 ft28 ftWarning[url=]Not Enough Force/ESC Error (repeated 29 times)[/url]
V11m 35s4.6 ft27 ftWarning[url=]Not Enough Force/ESC Error (repeated 19 times)[/url]
W11m 41s4.9 ft23 ftWarning[url=]Not Enough Force/ESC Error (repeated 50 times)[/url]
X11m 46s4.3 ft25 ftWarning[url=]Not Enough Force/ESC Error (repeated 43 times)[/url]
Y11m 51s4.6 ft25 ftWarning[url=]Not Enough Force/ESC Error (repeated 50 times)[/url]
Z11m 56s4.9 ft22 ftWarning[url=]Not Enough Force/ESC Error (repeated 50 times)[/url]
a12m 01s6.2 ft22 ftWarning[url=]Not Enough Force/ESC Error (repeated 50 times)[/url]
b12m 06s24.9 ft20 ftWarning[url=]Not Enough Force/ESC Error (repeated 50 times)[/url]
c12m 11s48.2 ft41 ftWarning[url=]Not Enough Force/ESC Error (repeated 50 times)[/url]
d12m 16s72.5 ft41 ftWarning[url=]Not Enough Force/ESC Error (repeated 50 times)[/url]
e12m 21s77.1 ft39 ftWarning[url=]Not Enough Force/ESC Error (repeated 50 times)[/url]
f12m 26s77.8 ft38 ftWarning[url=]Not Enough Force/ESC Error (repeated 50 times)[/url]
g12m 31s75.8 ft38 ftWarning[url=]Not Enough Force/ESC Error (repeated 50 times)[/url]
h12m 36s77.1 ft37 ftWarning[url=]Not Enough Force/ESC Error (repeated 50 times)[/url]
i12m 41s71.5 ft37 ftWarning[url=]Not Enough Force/ESC Error (repeated 50 times)[/url]
j12m 46s41.3 ft35 ftWarning[url=]Not Enough Force/ESC Error (repeated 31 times)[/url]
12m 49s22.0 ft29 ft
[url=]30% Battery[/url]
k12m 50s21.7 ft28 ftWarning[url=]Not Enough Force/ESC Error (repeated 50 times)[/url]
l12m 55s5.9 ft23 ftWarning[url=]Not Enough Force/ESC Error (repeated 50 times)[/url]
m13m 00s8.9 ft20 ftWarning[url=]Not Enough Force/ESC Error (repeated 50 times)[/url]
n13m 05s8.5 ft15 ftWarning[url=]Not Enough Force/ESC Error (repeated 50 times)[/url]
o13m 10s7.5 ft20 ftWarning[url=]Not Enough Force/ESC Error (repeated 50 times)[/url]
p13m 15s6.6 ft21 ftWarning[url=]Not Enough Force/ESC Error (repeated 50 times)[/url]
q13m 20s5.9 ft24 ftWarning[url=]Not Enough Force/ESC Error (repeated 50 times)[/url]
r13m 25s4.9 ft26 ftWarning[url=]Not Enough Force/ESC Error (repeated 50 times)[/url]
s13m 30s5.2 ft27 ftWarning[url=]Not Enough Force/ESC Error (repeated 50 times)[/url]
t13m 35s3.6 ft28 ftWarning[url=]Not Enough Force/ESC Error (repeated 3 times)[/url]
u13m 35s3.6 ft28 ftMode[url=]Mode changed to Confirm_Landing[/url]
v13m 35s3.6 ft28 ftWarning[url=]Not Enough Force/ESC Error (repeated 18 times)[/url]
w13m 37s0.0 ft28 ftMode[url=]Mode changed to Tripod[/url]
Flight time
Altitude
A00m 00s0.0 ft0 ftMode[url=]Mode changed to P-GPS[/url]
B00m 00s0.0 ft0 ftTip[url=]Setting new Return-To-Home altitude to 60m (197 ft). Data Recorder File Index is 64. Setting new Maximum Flight Altitude to 120m (394 ft)[/url]
C00m 00s0.0 ft0 ftMode[url=]Mode changed to Motors_Started[/url]
D00m 01s-0.3 ft0 ftMode[url=]Mode changed to Assisted_Takeoff[/url]
E00m 10s0.0 ft2 ftMode[url=]Mode changed to Tripod[/url]
F00m 16s3.6 ft4 ftTip[url=]Setting new Maximum Flight Altitude to 30m (98 ft)[/url]
01m 28s30.2 ft30 ft
03m 31s5.9 ft13 ft
05m 35s18.4 ft30 ft
06m 14s84.0 ft94 ft
[url=]67% Battery at maximum distance[/url]
G07m 07s7.2 ft7 ftWarning[url=]Not Enough Force/ESC Error (repeated 7 times)[/url]
07m 30s12.8 ft11 ft
H07m 34s10.8 ft9 ftWarning[url=]Not Enough Force/ESC Error (repeated 18 times)[/url]
I08m 14s9.5 ft7 ftMode[url=]Mode changed to Quick_Shot[/url]
J08m 36s96.8 ft8 ftMode[url=]Mode changed to Tripod[/url]
K08m 36s98.1 ft8 ftWarning[url=]Not Enough Force/ESC Error (repeated 50 times)[/url]
L08m 41s98.4 ft8 ftWarning[url=]Not Enough Force/ESC Error (repeated 22 times)[/url]
M08m 46s96.5 ft6 ftWarning[url=]Not Enough Force/ESC Error (repeated 15 times)[/url]
N08m 56s97.1 ft4 ftWarning[url=]Not Enough Force/ESC Error (repeated 25 times)[/url]
O09m 11s73.8 ft5 ftWarning[url=]Not Enough Force/ESC Error (repeated 20 times)[/url]
09m 27s48.6 ft6 ft
P10m 01s9.8 ft6 ftWarning[url=]Not Enough Force/ESC Error (repeated 21 times)[/url]
Q10m 07s5.9 ft5 ftWarning[url=]Not Enough Force/ESC Error (repeated 20 times)[/url]
R10m 56s97.1 ft64 ftWarning[url=]Not Enough Force/ESC Error (repeated 50 times)[/url]
S11m 01s91.9 ft64 ftWarning[url=]Not Enough Force/ESC Error (repeated 50 times)[/url]
T11m 06s90.6 ft65 ftWarning[url=]Not Enough Force/ESC Error (repeated 50 times)[/url]
U11m 11s80.7 ft66 ftWarning[url=]Not Enough Force/ESC Error (repeated 50 times)[/url]
V11m 16s77.1 ft66 ftWarning[url=]Not Enough Force/ESC Error (repeated 32 times)[/url]
11m 19s77.8 ft66 ft
W11m 19s77.8 ft66 ftWarning[url=]Not Enough Force/ESC Error (repeated 50 times)[/url]
X11m 24s77.1 ft65 ftWarning[url=]Not Enough Force/ESC Error (repeated 50 times)[/url]
Y11m 29s78.1 ft66 ftWarning[url=]Not Enough Force/ESC Error (repeated 50 times)[/url]
Z11m 34s64.0 ft52 ftWarning[url=]Not Enough Force/ESC Error (repeated 50 times)[/url]
a11m 39s46.3 ft40 ftWarning[url=]Not Enough Force/ESC Error (repeated 50 times)[/url]
b11m 44s32.2 ft29 ftWarning[url=]Not Enough Force/ESC Error (repeated 50 times)[/url]
c11m 49s16.4 ft17 ftWarning[url=]Not Enough Force/ESC Error (repeated 50 times)[/url]
d11m 54s8.5 ft8 ftWarning[url=]Not Enough Force/ESC Error (repeated 50 times)[/url]
e11m 59s8.2 ft6 ftWarning[url=]Not Enough Force/ESC Error (repeated 50 times)[/url]
f12m 04s8.5 ft5 ftWarning[url=]Not Enough Force/ESC Error (repeated 45 times)[/url]
g12m 13s9.2 ft12 ftWarning[url=]Not Enough Force/ESC Error (repeated 50 times)[/url]
h12m 18s9.2 ft13 ftWarning[url=]Not Enough Force/ESC Error (repeated 34 times)[/url]
i12m 27s12.1 ft13 ftWarning[url=]Not Enough Force/ESC Error (repeated 22 times)[/url]
j12m 33s12.1 ft14 ftWarning[url=]Not Enough Force/ESC Error (repeated 49 times)[/url]
k12m 38s10.2 ft13 ftWarning[url=]Not Enough Force/ESC Error (repeated 16 times)[/url]
13m 12s6.6 ft5 ft
l13m 33s5.2 ft14 ftMode[url=]Mode changed to Quick_Shot[/url]
m14m 06s24.3 ft11 ftMode[url=]Mode changed to Tripod[/url]
2020-1-19
DJI Paladin
Flight distance : 318 ft
Hi. Thank you for sharing your experience with us with regards to this concern. This will help a lot of our DJI co pilots who are experiencing the same concern with their DJI Mavic Mini. Again, thank you for your valued support and have a safe flight always.
2020-1-21
