BATTERY ERROR TB 50
1103 1 2020-1-23
i-dron
Flight distance : 204409 ft
Good morning, the other day discharging batteries in the charging case I got an error in a tb50 battery (the batteries have about 70 flights) I got a battery at 0% and the voltage of each cell at 4.30 volts.
These errors have happened a long time ago in the UK. I have the latest versions in both the charging case and the batteries since the update came out and now I get this? I left that pair of batteries unused, yesterday flying the equipment happened to me the same with other batteries less badly it was in one of them and I was able to lower the equipment without problems.
I do not know if someone else is the same but this is a fairly important problem since the equipment can fall on someone and cause major problems, I do not understand how expensive equipment can have these problems.
I am waiting for you to say DJI.
2020-1-23
i-dron
VIDEO
2020-1-24
