I noticed that on the "update home point" screen (UHP), there is no option to select different layers on the map (standard, satelitte, mixed).
This option is only available on the realtime map of the flight.
Why??
I have had two emergency situations, when I wanted to update home point mid-flight. But when I got to the UHP screen, there was no option to see satelitte map, to double check, that there is no obsticle there. (trees, barn, ...)
If you are in the middle of field, you can`t see any reference point as well.
This safety function should be added as soon as possibble.
Any thoughts?
homepint_satellite_map_safety_request_mavic_mini
