hallmark007
Flight distance : 9827923 ft
Guorium Posted at 2-5 06:10
Well DJI certainly will say no. But as someone who knows what a vision-based speed control is (VPS) and its working principles, I can tell you at suitable height and visibility of the bottom pattern, downward camera of tello which is the identical camera used in mini can give a steady position lock. Tested many times by me over lakes, rivers and wavey oceans. Why? Shallow water is clear, my Scottish genius. Clear like your Scotch.
Good luck communicating with Gaelic here. Would be pitiful if you do since I will not find that amusing anymore.
Right same vps sensor with tello as mini , so how do you figure tello vps sensor has limit of 6m, are you still making up stuff as you go along?
The reason why vps gets confused over water is because of the movement in the water, but for you it’s not a problem, and reason it’s mentioned in the manual according to you is wrong, so maybe dji wanted to catch you out.
You need to go back and look at your conflicting comments, first you can’t believe it’s VPS and you don’t understand how vps works, then it barometer because , well you give no good reason except to say that’s what dji told you , it looks like your learning as you go, one step forward two back . |
