Veenstra85
DJI Gamora Posted at 2-13 09:30
Hi, thank you for reaching out and we're sorry for the inconvenience caused. Can you please try to uninstall the application and reinstall it again using the link below. Please check if the USB debugging option was already enabled to ensure that the mobile device will communicate with the unit. Please go to developer mode, enable the USB debugging and put default USB mode to tethering. Also, please make sure that you are using the updated firmware for both Aircraft and RC to avoid any issues. Please keep us posted. Thank you!
https://www.dji.com/downloads/djiapp/dji-fly
Hi,
I had the same problem.
1. Connected Phone to DJI Controller
2. Phone (Galaxy S10 Plus) Battery is loading, popping up every time.
3. Can start DJI FLY app but no connection between phone and Controller, Still having the pop up, that the battery is loading from the S10 Plus.
I have tried the steps:
- USB Debugging mode is enabled
- Default USB Mode set to Tethering.
- With another phone (Samsung Galaxy s20) I have updated the firmware on the controller and the Mavic Mini.
- Deleted the DJI Fly app on my phone (S10+), restarted phone and installed DJI FLY app again.
Still having the same problems. Can you please help me?
Cheers,
Nick |
