SKyHigh05
Flight distance : 60364 ft
Malaysia
DJI Gamora Posted at 2-20 07:51
Hi, thank you for reaching out and we do apologize for the inconvenience. Can you please try to uninstall and reinstall the DJI assistant 2 to see if the problem persists. Also, may I know what mobile device you are currently using? You may refer to the information below on how to export logs using the mobile device. Should you have other further concerns please don't hesitate to reach us. Thank you!
Flight Record and Simplified Data Export
Thank you for your prompt reply Gamora. Also for the screenshots. I have reinstalled the DJI assistant 2, but there is no success. I am using an IOS device. However i tried with the iTunes, which did manage to export some files, both, for flight records and logs. But the MCDatFlightRecords folder is empty, is that how it is supposed to be ?
Also, is using the iTunes is an alternative to export the log, or it has limited use and cannot export all the files, which the DJI assistant 2 could. Thanks again. |
