DJI Tony
Hello there. Thank you for reaching out. Can you please try the steps below and see if it will help:
1. Please check the Sensor Calibration Instructions in DJI Assistant 2. During calibration, keep the aircraft arms unfolded. Notes: Folded aircraft arms may obstruct the vision sensor, which may result in a calibration error.
2. Ensure that the monitor has a straight-face screen. Curved screens are not supported.
3. We recommend using a monitor larger than 14 inches. If the screen is less than 14 inches, the calibration may fail.
4. Please use a soft fabric (such as a cloth for glasses) to wipe the vision sensor lens of the aircraft. Wipe it several times until the lens is clean.
5. Please set the resolution displayed on the computer to the default value recommended by the system.
6. Try to reinstall the DJI Assistant 2. Make sure you are using the correct version.
7. After following the steps above, please reconnect the aircraft and the DJI Assistant 2 for reconnection and calibration.
Please keep us updated. Have a great day ahead. |
