Motion-lapse is that bad?
757 7 2020-3-29
Cipri
Flight distance : 407001 ft
Hi all,
I'm trying to level up my time lapses and did some tests on the ronin s with the motion lapse function.
The sequence is really shaky even if it's everything balanced and tested. The setup is GH5 + 18-35 Sigma so I don't think that there isseus with the weight.
With the stabilizer of an NLE it gets really better but the subject is flat (just the sky and the sun), I'm worried that once there's movement in the footage, the stabilizer is going to make weird artefacts. Does anyone found a way to have a nice and smooth motion lapse? Thanks
2020-3-29
Hi Cipri, for more stable motion lapse, we recommend to enable the mute shutter of the camera, and avoid other external factors interfering when shooting. For the small jitter, it can be eliminated by the third-party software, and the effect will be greatly improved.
2020-3-30
Montfrooij
Flight distance : 2560453 ft
Were you outdoor with wind?
2020-3-30
Cipri
DJI Mindy Posted at 3-30 04:24
Hi, actually there were not external factors and the stabilizer, even if improved the footage, is still moving weird...the problem is that it moves in all directions so it take lot of work to have a fluid sequence...
2020-3-31
Cipri
Montfrooij Posted at 3-30 23:06
No, it was indoor
2020-3-31
Montfrooij
Cipri Posted at 3-31 05:24
No, it was indoor
That is strange.
2020-3-31
kanapee
Austria
@Cipri I wouldn’t use the Ronin S for a Motion lapse. You have too much movement, as you experienced in the entire setup.
2020-4-20
sky_makai
Flight distance : 3397539 ft
I think Mindy's saying to try using 'silent shutter', as the shutter actuation may be vibrating the camera.  This doesn't make a lot of sense to me, as the Ronin-S should be able to handle the small vibration of the shutter.
My experience with the Ronin-S is that it does not stay stable during a static time-lapse.  So, a tripod is the way to go for that.  For a timelapse with an automated pan/tilt, I think the Ronin-S does best as it's constantly moving.
For motion lapse, using After Effects to track and stabilize is the way to go.  I have a friend, Scott Herder, who made a course about it.  It's called Hyperflow Masterclass.
2020-4-28
